KManager V1.2.1.5
KManager V1.2.1.5
V1.2.1.4 (1 Mar 2006)
* Added TPS ignition retard to the PRA ECU
* Added overrun cutoff to the PRA ECU
* Added the option to show 5 bar columns
* Fixed VSS output for PND ECU
V1.2.1.5 (9 Mar 2006)
* Re-release with new version number.
Download here
i vietec
Post by i vietec »
If I enter -100.0 for all gears in TPS Ignition Retard does this mean that this function is disabled. What was the original factory setting for TPS Ignition Retard? Is there a way that I can disable it completely because my car ran a lot smoother before this feature was introduced. Thank you.
-100.0 will disable the ignition retard. This feature was always there - it was only in recent versions which it was possible to edit the values. If you think your car smoother previously it was for some other reason.
portandpolish
Post by portandpolish »
Just a little reminder, that I posted my Kal and .Kdl files here:
http://hondata.net/forum/viewtopic.php? ... c&start=15
Thnks.
EP3, K20A, Toda Race Header, Injen CAI, IMG, K-Pro
