Resetting K-Pro
Civic-R
Resetting K-Pro
Post by Civic-R »
How to reset my K-Pro ecu?
Toda Spec C Vtec Highcam,Toda Exhaust Manifold,Toda Valve Springs,Toda High Compression Piston,Toda Campulley,Mugen Air Cleaner Box,Mugen Metal Head Gasket,Mugen Fan Switch,Mugen Thermostat,Mugen Ignition Coil Cover,
YOu can erase teh ecu and clear it by going to ONLINE, TOOLS, and click on CLEAR SECURITY. You will then have to upload a calibration.
o2ep3hatch
Post by o2ep3hatch »
Spunkster wrote:YOu can erase teh ecu and clear it by going to ONLINE, TOOLS, and click on CLEAR SECURITY. You will then have to upload a calibration.
did this.. now my ecu doesnt make the clickin noise it made when u upload a map. and the car revvs at 3k spudder and backfiring.
worried..
any info ?
hmmph
First, if you have an engine swap or any part of the ECU wiring harness has been altered, stop and go no further until you have fixed the vehicle wiring.
Next make sure that your laptop recognises the ECU ('online' in the bottom left) and shows when the ignition is on ('ignition on' in the bottom left). If this doesn't happen, stop, go no further until you have fixed the problem (which is probably USB drivers).
Then clear the security. Again, if this doesn't work, there is no point going to the next step. Now upload a calibration. If these steps don't work, there is little point even starting the car. Check that the KPro is listed in the device manager as 'Hondata K-Series ECU' (these steps are in the help file). If still no joy then try a different laptop and/or try the ECU in a different vehicle (difficult with a 05).
