Socketing Price
V8Whaaa
Socketing Price
Post by V8Whaaa »
Hey guys im new here, Searched the site but cant seem to find solid answers on what im looking for,
I bought S300 system from a local guy and already had my P28
What does Hondata Charge to send my ECU and my S300 in to be socketed and changed to obd2 connectors?
will Hondata work on my ECU since i didnt buy S300 from them?
Also what is the Turn Around Rate on an ECU?
thanx again..sorry for the newbie questions..i know its been answered before probably...
http://www.hondata.com/ecusocketinginfoform.html
THe connectors cannot be changed. You will have to purchase a regualar adapter harness.Turn around time is typically 1-2 days once it is received.
The s300 does not have to be sent in.
V8Whaaa
Post by V8Whaaa »
thats cool...i already knew about the form...i just didnt see where it said i had to send S300 in to be installed...but i was reading the DIY install and it said about some chips....basically all you guys do is socket my board with the nessasary pins...or do you do the entire S300 mods like cutting the case and totally setting it up?
thanx again
Why is it a V8 guy always says there is no replacement for Displacement, when us Import crew have found it...its called P SI!!!
If the form is filled out and you select the socketing for the s300 then the case will be cut and it will be made ready to accept the s300.
flip1199
Post by flip1199 »
ok i'm in norcal. i bought a s300 on tuesday and according to ups's site i should have it on the 28th. problem is i have a race on the 1st and 2nd. do i have to send you the ecu and the pins or can i just send u the ecu now and you provide the pins? is it an extra cost to do it like that?
the parts are all included in the price of socketing.
V8Whaaa
Post by V8Whaaa »
good useful info here...thanx guys..you will get my ECU next week...also what is the turn around for normal 75 dollar socketing???
