Lean Protection and OBDII
nrzforce
Post by nrzforce »
Does Lean Protection work if OBDII is disabled?
For example I had lean protection on for my N/A 02 rsx-s with only a SRI and lean protection would kick in right around 5k. I put a JRRH and Megan Cat back exhaust on. Set the trigger time from stock to 550ms and disabled OBDII and now it never goes lean. Is this b/c of the header/exhaust? Trigger time? or OBDII?
OBD2 should hav enothing to do with the lean protection. You will have to look at your datalogs and see if the reason that you aren't hitting a lean cut is because you are no longer going lean.
nrzforce
Post by nrzforce »
Spunkster wrote:OBD2 should hav enothing to do with the lean protection. You will have to look at your datalogs and see if the reason that you aren't hitting a lean cut is because you are no longer going lean.
Awesome, thanks for the info. I thought I read somewhere that Lamdba was a reading from the Secondary o2 sensor. I'll data log tonight and see whats up.
nrzforce
Data Logs
Post by nrzforce »
Here is a couple datalogs. I was wondering if anyone could tell me how much fuel I need to take off?
I used the rsx-coldair.kal
