Duty cycle/injector duration accuracy
NA2BOOST
Post by NA2BOOST »
Im curious how these numbers are obtained. They do not seem accurate to me. I have 600cc injectors running 8 psi of boost. According to smanager I'm at 90% duty cycle with injector duration peak of 14.6ms. I'm running 42psi fuel pressure with the vacuum reference at atmosphere. Now originally I thought, maybe it is a fuel pump problem. so I hooked up a pressure gauge to monitor fuel pressure under boost and it is a steady 51psi. When I first started to tune I had to use the overall fuel trim at 30% to get in the ballpark after using the injector sizing. Does that affect the duty cycle calcs? The car runs good, but i'm nervous about that much injector duration.
Accurate to about 1% according to my oscilloscope.
