What solder and tip temp. to use when prepping P75 for s300?
TurboLS
Post by TurboLS »
what solder and tip temperature should I use when installing s300 into P75? The last thing I want to do is toast my ECU, but I don't really feel like paying $65 for 20 minutes of soldering.
TurboLS from Team-Integra.net
(703)919-2786 (C)
around 425 C
Keep in mind that a number of people that attmept to socket their own ecu's end up damaging them. IF the ecu has previously been socketed, i highly recommend sending the ecu to Hondata to be prepared. If you do not have a proper desoldring gun then I also recommend sendign it to Hondata.
TurboLS
Post by TurboLS »
Mine is a virgin ECU. Actually, I was trying to find R54 on this P75 ECU. I can't find it to save my life. However, I'm not gonna do anything else until I locate it. thanks.
(703)919-2786 (C)
sulsa76
Post by sulsa76 »
I just recently read that the P75 and the P72 don't have the R54 resistor. So you can stop looking, hehe. I looked for it on my P72 for about 20 minutes myself.
94 Integra LS with NA GSR block/head
Endyne pistions, 14 pound flywheel, Civic SI crank pulley, honed gsr intake manifold, 70mm BBK TB, Stock GSR cams, stock exhaust/header
