p74 ecu
jeff
p74 ecu
Post by jeff »
is the p74 ecu from the 94 teg just a myth ? I have been searching for a while and no luck. I have a 90 si running a very built b18a with a stock pr4 ecu i just purchased a s300 system and am under the impresion that the p74 is better. any help would be great
The obd0 pr4 will not work with the s300. You will have to use the P06, P74 or P75.
