Best way to wire wideband...?
beyond-redline
Post by beyond-redline »
I can pretty much do whatever will work best. I have a second o2 sensor bung in my exhaust. Should i keep the stock sensor and wire the wideband into the eld? I'm using the innovative lc-1. What about the difference between open and closed loop, i don't quite understand the best way to run this. I have read some other posts but most people don't have the second bung. Any guidance would be appreciated.
Tim
With 2 bungs, you should keep the stock o2 and just feed the wideband signal to the ELD.
