Nitrous kal
thesilverbullet
Nitrous kal
Post by thesilverbullet »
Hondata,
Would you post the 40 and/or 80 shot kal file for the nitrous dyno you guys did awhile back (w/ stock injectors & CAI on a k20a2). I found the fuel adders in kmanager help. i'm looking for the suggested timing adjustments over the stock tables.
a few questions...
you guys made 283hp @ 7,000rpm on stock injectors. is it possible to hit ~300hp @ ~7,400rpm with cai, rh, and 2.5 comptech exhaust?
Do you have a datalog of the dyno runs? - i would like to know what MAP readings you were getting with the 80 shot ~3psi?
Last edited by thesilverbullet on Sun May 07, 2006 2:12 pm, edited 2 times in total.
'23 RDX SH-AWD
'07 S2K w/ JVT header, Berk 3" header back w/ TP Exhaust, AEM V3 CAI & Flashpro
'02 RSX-S w/cai/exhaust/dcrh/kpro - SOLD
Re: Nitrous kal
thesilverbullet wrote:is it possible to hit ~300hp @ ~7,400rpm with cai, rh, and 2.5 comptech exhaust?
Probably not. The injectors are too small.
eurofixer
Post by eurofixer »
283 hp at 7000 rpm! That was an 80 shot only? Just wondering what is the biggest shot that the stock injectors can handle up to 8000 rpm.
thesilverbullet
i agree would be nice to have more info. they also dyno'ed a 40 shot but did give any details. would be interesting to see a two stage system around the 8+K range like a 40 shot plus a 20 combo. or maybe a pair of 40 shots and drop one out around 7k and just run a 40 shot from 7-8+k...
'23 RDX SH-AWD
