cam question: will this work?
silver bullett
Post by silver bullett »
On another forum I was told that a zex cam from a d16z6 would fit in a d16y8 is this true?
Contact ZEX
Clutch
Re: cam question: will this work?
Post by Clutch »
silver bullett wrote:On another forum I was told that a zex cam from a d16z6 would fit in a d16y8 is this true?
Yes ... physically it will fit but the cam timing will be off due to the differences in the cam gear slot on the cam itself between the z6 and y8.
silver bullett
timing difference
so will a adj cam gear fix this? and should I use one from a z6 or a y8? I already have one from a z6 (aem) will this work?
Clutch
Re: timing difference
Post by Clutch »
silver bullett wrote:so will a adj cam gear fix this? and should I use one from a z6 or a y8? I already have one from a z6 (aem) will this work?
Yes ... either one will fit. The y8 adj. cam gear will have to be adjusted for a z6 cam whereas the z6 cam gear will be set at zero. It will be just the opposite with a y8 cam.
