Hondata for '06 Civic Si
Alex Soriano
Post by Alex Soriano »
I was wondering if there is any info on when Hondata will be available for the '06 Civic Si? I imagine the MAF sensor makes it a little tougher to modify. I think a lot of us new Si owners will be interested in getting the Hondata ECU upgrade as soon as it is available.
Alex
We'll let you know on the main Hondata page when something is available.
SwitchedOn
Post by SwitchedOn »
Hondata wrote:We'll let you know on the main Hondata page when something is available.
So...there's no ETA...off the record?
This is not like building a house - it has not been done before, so we can't estimate when we will be finished.
SwitchedOn
Ok...just checking. I trust you'll let us know when it ready.
nafunu32
Post by nafunu32 »
I know that you have stated you do not know the ETA. Is there any way you can inform us on what you have already completed, what you have left, and what are all of the plans for the ECU? We are anxious ;)
SwitchedOn
!!!!!!!!!!! IT'S HERE!!!!!!!!!!!
http://www.hondata.com/reflash_06_civicsi.html
Now, how much longer do we have to wait for the K-Pro???
Any Idea?
The 2006 ECU is difference from earlier RSX ECUs, and a KPro style programmable solution is not possible.
RaskyR1
Post by RaskyR1 »
(Race header / Test pipe. This will eventually give you an engine check light telling you have a faulty catalytic converter. We have not seen this error cause any power loss.....)
So I there a way from keeping the check engine light from coming on with the header?
No. Don't even mention spark plug defowlers or o2 simulators. Run a cat.
sickyute
Post by sickyute »
is there a problem that we should be aware of running the defowler or simulator?
or is it just a recommendation of the right thing to do?
thanks in advance.
Do not run o2 simulators. We see many ECUs which have been damaged by o2 simulators.
sickyute
Post by sickyute »
Hondata wrote:Do not run o2 simulators. We see many ECUs which have been damaged by o2 simulators.
does o2 simulator mean spark plug defowler also?
or is the spark plug defowler ok to run but just stay away from the o2 simulators?
sf-si-02
Post by sf-si-02 »
no defowler is diefferent., Though the risk is that if your car is lowered, I have seen the sensor get sheared by the road on other k-series cars...
