will my old injectors work?
rickoner
Post by rickoner »
i have a k24a4 in a 94 hatch w/K-PRO. my engine didn't come with injectors and was clipped for obd1's. i plan on getting some rc 550's but in the mean time i would like to start my car and check to make sure everything is operating correctly. i have some stock b-series injectors laying around and i got them to fit with no leaks up to 65psi. will those stock 240's be compatible with the K-PRO? or could it damage the ecu?
as long as they are saturated then you can use them. I'm not sure how you got them to fit, since RC machines them differently.
rickoner
Post by rickoner »
to get them to fit you just have to use the right size o-rings (top and bottom), longer fuel rail mounting studs and spacers. thanks for confirming that they will work before i test fire.
