Close Loop in 13.9 - 14.0
Dariusz
Post by Dariusz »
I like that my close loop AF is 13.9 - 14.0 in close loop, what is the value I need to set in the target voltage in a S-200?
Thanks in advance,
Dariusz
Dariusz
Post by Dariusz »
This not help, I think that a person working in Hondata can have a little more details ?
In other topic I send you a rom editor file and you say that 0.7 is a bad value, how do you know that?
what sensor are you using for the narrow band input? What are you referring to about .7 being a bad value in romeditor?
Dariusz
Post by Dariusz »
- My sensor is the honda OEM
- "What are you referring to about .7 being a bad value in romeditor" Read your ansver from this topic: http://hondata.net/forum/viewtopic.php?p=13121
I need a little help for the specific question I make. We come here to the forum searching a little help from the Hondata people, the 90% of the forum members are Hondata users (we have the product installed in our cars).
From the graph you can see that 14:1 is around 1.0V. However, the stock o2 sensor is not very accurate, and using the target o2 voltage to adjust the lambda that much won't work very well.
