Factory settings
cukali
Factory settings
Post by cukali »
Can one get a copy of the factory settings?
Also, I was under the impression factory fuel cut off was above redline... around 7000-7200. Can someone clarify?
I have three dyno runs that go to 7200. Is this accurate?
thnx
You have not provided enough information to give any type of answer.
Stock calibrations can be found in the software by going to File, New.
cukali
Post by cukali »
Well I certainly left no info. I guess I was going to fast.....
K20A3 factory cutoff?
EP3 Factory maps?
thnx again.
Factory rev limiter for the K20A3 is 6900 rpm. The stock tach is not accurate. The factory calibration is available under File, New...
