Idle Problem
SoOperGeeSeR
Idle Problem
Post by SoOperGeeSeR »
Hey. I'm a newbie to s300... i just got the jackson racing high boost supercharger system and it came with s300 and 440 cc injectors. i loaded up the calibration for b18c supercharged 440cc injectors. when i first turn the car on it idles fine. after i drove it around and let off the gas, it idles low than turns off.. but it'll start up just fine again... any help?
If you disconnect the Idle control valve, what does the car idle at?
SoOperGeeSeR
500 RPM
You may need to make some adjustments to the idle control in the Smanager software.
picnic_george
Post by picnic_george »
You should post the .skl.
