3Bar Map Sensor Help
marcs23
Post by marcs23 »
I hooked up a GM 3-Bar Map sensor. I changed the setting in K-pro to the Neetronics 3 bar setting. Car will not start. I pluged the stock map sensor back in and car starts fine. I am almost positive my wires are correct. What else can it be or what shoudl I check?
Mods:
Greddy turbo
FMIC
K-pro
650CC injectors
More than likely you have the wrong GM sensor. We do not recommend the GM sensors because there are several types and they all have different calibrations. We only recommend usign the Motec sensor. If the setting fro the Motec sensor does not work, then you problably have hte wrong sensor or it is improperly wired.
