k20z1 into dc2 (what do i need to make speed sensor work?)
Jordo
Post by Jordo »
The setup consist of:
2000 integra type r
2005 k20z1
2005 k20z1 6 speed tranny
2004 k20a2 engine harness
2004 k20a2 kpro ecu
Hybrid racing pnp harness
what exactly do i need to get to get the speedo to work?
s300
The best option is to sell the 05 transmission and use an 02-04 transmission. You could use the 05 engine harness and an ECU modified for an 05, but even I think you'll have trouble with the cluster.
and using the 05 harness wil only account for 2 of the ecu plugs. Just get the 02-04 harness and sell the 05 transmission and get a 02-04.
Jordo
Post by Jordo »
Spunkster wrote:and using the 05 harness wil only account for 2 of the ecu plugs. Just get the 02-04 harness and sell the 05 transmission and get a 02-04.
so once i get the swap in my only problem will be the speedo not working? because buying a 02-04 tranny just is not an option
s300
Thats just one problem...which will lead to many more.
Jordo
Post by Jordo »
there is a guy on honda-tech who makes a "speed converter"
"bigcalidave" is his name
http://www.dscustoms.com/s2000cluster.htm
He makes one that will work for K-series into normal clusters.
s300
