Help with TWM ITB setup..
Hassan
Post by Hassan »
Hi,
I am running twm ITBs on my b18c5. The TWM setup comes with its own tps. Is there any way to calibrate the throttle range? Because right now at full closed the tps reads 26%
Also anyone have a base map for an ITB setup?
Thanks in advance.
Hassan
B18C5-EF
S300, ITBs etc...
You'll need to either adjust the TPS, modify it to use a Honda TPS or contact TWM about why it is reading incorrectly.
TTR
Post by TTR »
Make sure you are reading throttle percentage with the engine running. Just having the ignition on, and connected, the default percentage is 26 percent. Or the most accurate way to set the TPS is use a multimeter. With the ignition on, ground one probe to the chassis and probe the signal wire with the other lead, it should read .5 volts closed, 4.5 open, good luck.
sumitomo
Post by sumitomo »
I,have a crv-tec and also have a twm itb setup.I sorry I cant offer too much help at this time I am going to wait until next year to install as autocross is now.I am very interested in how this is going to work for you.Please keep me updated thanks.sumitomo
