failure to load
xzerozx
failure to load
Post by xzerozx »
Alright, i can datalog and see everything ok, its just when i try to upload a map it says failure to load
this was happening before but it took consequentive times to of uploading it to fix it and some wiggling of the usb, but now it keeps on doing it
im thinking somehting is loose on the board, but also my usb when i put it in once, it was a little tight but now its fine
and yes ive tried updating usb drive and getting new version of kman and reverting back to old ones
car is an 02 ep3
xzerozx
Post by xzerozx »
to be more specefic, i try to upload, the screen pops up that has the bars for the loading (more bars=more loaded and almost done)..and it gets 0 bars then 1/2 sec latter an error box pops up saying load failed
when the usb cable is in, i look inside the hole on the ecu where the usb cable is and see a red light blinking,, when i load it flashed red sometimes...this is the light under the green one and isnt on when usb cable is out
open the lid and see if there is anythign loose. Also remove the K-Pro board and make sure none of the pins or connectors on the board are damaged.
xzerozx
Post by xzerozx »
when i remove the kpro board, its just that one screw? is there nething else to worry about?
is everything secure?
