Engine splutters at low rpm
aam
Post by aam »
Hi,
I have a Euro CTR with N2 cams, DC Sport Header, and K-pro.
The car has been setup on a rolling road, re-mapped and is producing good power. However at low rpm the engine splutters just as the throttle is cracked open. This results in an annoying lag before the car starts to pull cleanly. It is most noticable in first gear from a stand still but is also there in 2nd and 3rd if driving slowly and short shifting.
I am very much an amature so any help with adjustments to the K-pro would be much appreciated.
Thankyou
Alan
The tuning/mapping is incorrect at that part of the map. Identify what rpm and load range the problem occurs, and post your calibration. In KManager reduce the throttle tip in ignition retard to -100%
aam
Post by aam »
Hi,
I checked the TPS Ignition Retard table and found it to be 17.2 for gears 1,2 and 3, zero for 4 and -100 for 5 & 6. I re-set this to -50 for gears 1,2 & 3 and found the problem was solved.
Thankyou for your help
geno
Post by geno »
I have problem like this also.
Toda N2,Toda 421,K-Pro,AEM.
Car splutters where car goes to VTEC :(
I shall make new post with KAL & KDL when home.
Geno
aam
Post by aam »
The problem I asked about in this post was splutter at low rpm just as the throttle was cracked open, nowere near VTEC. I adjusted the TPS as hondata suggested an that went away.
However after I had my N2 cams fitted and the car re-mapped I found it did something similar to yours on part throttle just on VTEC switch over, Ok WOT. This sounded and fealt similar to a missfire and the car lost power until the revs got up a bit. The lower VTEC point had been re-set to about 3500rpm however I found the problem got better by moving this up to 5250rpm.
N2 cams, DC Sport header, Kpro, Mongoose exhaust, Blitz intake.
Alan
geno
Post by geno »
aam wrote:The problem I asked about in this post was splutter at low rpm just as the throttle was cracked open, nowere near VTEC. I adjusted the TPS as hondata suggested an that went away.
Alan
Yes when throttle is 50% then car misfire. When car on WOT car ok. :?
KDL and KAL for Hondata help
Thank you
Geno
The problem is at 4500 at part throttle on the high cam. Ideally you need to tune this region with a wideband, but here are some thing to try first:
Lower the VTEC lower window pressure from 98 kpa to 90 kpa or so, otherwise VTEC will be delayed at elevation.
Set the TPS ignition retard to -100%
Change the maximum MAP for closed loop to 65-75 kpa as this is giving the injector duration some hystersis at the present 80 kpa setting. It could be that the engine is running a little rich in this area (4500 rpm) or that the VTEC point is too low.
You might want to try raising the VTEC upper pressure from 24 kpa to 60 - 80 kpa to see if that helps the hesitation you see.
geno
Post by geno »
Thank You Hondata I shall try :D
