Doubt
RedR
Doubt
Post by RedR »
I?m running the s300 on my car, but from time to time it seems the software forgets the defined target lambda and goes back to its original values, is this a bug or something?
Can you be more specific and post calibrations and datalogs?
RedR
Post by RedR »
for example i set target lambda to 14.7 low load, 13.2 medium load and 11.8 high load, and after loading the map a few times it goes back to the pre defined values ( 14.7 / 13.5 / 12.5 )
Can you give a sequence of operations which will reset the values?
RedR
Post by RedR »
it happens after i start the s300 manager a couple of times and load the map im tuning, lately havent had any issues though (not that i can call that an issue)
