a noob! please guide
kaisar1
Post by kaisar1 »
i first visited Hondata.com 3 days ago, and since then i was in interested in buying their system...
I belong from Pakistan, and here you can find loads of JDM D15B Vtec's with OBDI P08 Ecu's and also the domestic models with D16Y6 motors with P06 ECU's ..
wht im really confused about is , is Hondata S200 systems are for single use? i mean i bought e.g a S200 and installed it in relative ECU and finised with it, or these systems are for upgrading ECU's unlimitedly? Like are systems for a single user or a techician/electrician?
Each vehicle must have a Hondata sysem installed in it. I would recommend the s300over the s200 as it has alloptions, is easier to make changes and is real-time programable.
kaisar1
Post by kaisar1 »
im a mechanic actually, and need a professional system to tune the vehicles here, having said tht i need a system to upgrade stock ECU coded P08 and P06....whts the best system hondata is offering? Professional Ones?
I would suggest looking at http://www.hondata.com/aboutus.html and http://www.hondata.com/ecus.html
If these are JDM ecu's I would recommend the s300j.
