First Time Using Hondata/Can't Get IT TO Idle Smoothly
The Jacko
Post by The Jacko »
My buddy just got the s300, I uplaoded on of the calibration maps into the ECU. I changed his injector sizes. I tried to pour fuel but still nothing. For some other reason the car idled between 1000 to 1250rpm, but it does that in column five and six. Also in some spots the ignition looks really low to me. I am in desperate need of help. I would like to show the map but I could not download it as an attachment. Would someone tell me how to do it.
Is this with the car fully warmed up that it has the high idle? What does the car idle at with teh IAC disconnected?
You just choose the location of the file you wan tto attach where it says browse, then after finding the file double click it and then submit.
The Jacko
Post by The Jacko »
I disconnected the IAC and the car wants to stall. Still working on posting the map.
set the map properly per the Helms manual instructions before going any further. Then you can make adjustments to the idle controll slider and the water temp idle tables.
The Jacko
Post by The Jacko »
:? sorry,what is the Helms manual and where can i get it :oops:
alex
Post by alex »
what map sensor are you using?
go where crows go
know what crows know
Helms manual is the factory service manual
www.helminc.com
The Jacko
Post by The Jacko »
alex wrote:what map sensor are you using?
It's a stock map sensor
The Jacko
Post by The Jacko »
Spunkster wrote:Helms manual is the factory service manual
www.helminc.com
I have a haynes manual
