which ecu should i use
b16hatch
Post by b16hatch »
ok i have a 91 civic hatch that im about to complete my motor swap inn.. the motor is a b16a1 and is currently obd0.. i have a pwo ecu.. im wondering when it comes time to convert to obd1 and get ready for boost wich ecu and hondata system i should use...
You will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100, s200 or s300 depending on what options you want.
b16hatch
Post by b16hatch »
so i can use any of the obd1 ecus.. jdm or the us ones?
You can use anything listed in that link.
b16hatch
Post by b16hatch »
thanks alot for the help
