P28 D16Z6 Calibration = correct ?!
Nagata-San74
Post by Nagata-San74 »
Hello
I tried to upload the D16Z6 calibration this afternoon
The car starts, but I've an error code...
when cold, the stock idle was 1400rpm
now it's 1000
the stock (cold) A/F was 13,1
now it's 14,8
and the car rolls VERY bad, I've been scared to drive, so i didn't
The ignition seems very hard, and many mistakes make me think it's a B16 calibration (ex: rev limit: 8500 instead of 7500...)
help :roll:
'94 D16Z6 Hatch Civic from France
Nagata-San74
UUU
You'll have to start making changes to get it to run the way you would like.
Nagata-San74
I tought calibration was ok to make the car run safe while stock :o
mark3000
Post by mark3000 »
Ive got the stock calibration from s300 and my car runs great! I only changed the fuel injector size and the idle. You sure you are using the d16z6 map? Any other changes on your car? Is it on closed or open loop?
Nagata-San74
I'm using the P28 basemap... I think it's the D16Z6 !
could you send me your map, with changed inj size and else...
Spanky
Post by Spanky »
do you have the latest version of s300? i ran 22lbs of boost on a d16y8 daily starting from that basemap. for your idle, play with the iacv settings. you can also play with the cold start, but i find that you really do not need to. what error code do you have? make sure that the light in your s300 is green and not constant red.
"My other car is a camaro, but today I was in a hurry."
