extrapolate how does it work
Importbanger_001
Post by Importbanger_001 »
Whats up guys,
Can someone explain to me how the extrapolate option works in S300 what does it exactly do.
If I have my mapping tuned up to 16 psi how do I extrapolate it up to 28 psi?
thanks
If you mean interpolate, then you may want to go to Help, Contents and on the Search tab type in interpolate and read the results. This you may find more informative than trying to explain it here.
alblude
Post by alblude »
you could use the formulas the attached file adds to your Excel to interpolate, but not sure how it'd work in your case since your trying to come up with values that are out of your current map range. Interpolation will need values from the sorrounding cells if you will... but you could give this a try, it's a demo version good for 15 days... change the extension to .msi instead of .txt once u download it.
