please help, limp mode
clay
Post by clay »
i installed the s300 in to my p 74 about 3 month ago, since the i've had the car tuned and it has ran fine. Then a few nights ago while i was drivng around town the car cut out on me and threw a cel. Now the car appears to be in limp mode, it wont rev past 3600 rpms, i cant datalog, and it wont tell me which codes it has thrown. i downloaded the maps out of the ecu to my laptop but the where all way off (everything is flat, and all parameters are off). i took the car to my buddies shop to see if he could pull the codes out with his snap-on scanner but he said he got no output from the ecu. Any and all help will be appriated, thanks.
Djbower1
Post by Djbower1 »
Is the red light inside flashing?? I guess you've tried uploading the calibration again ?
clay
Post by clay »
no, i doesnt flash, it stays solid red. yes, i have re uploaded the calibration.
Djbower1
Post by Djbower1 »
Im sure Hondata will step in and point you in the right direction.
Hope you get it sorted.
It is the ECU socketing.
