problem with idle after cold start
oscar93turbo
Post by oscar93turbo »
after cold start the car idle well then it goes to 3000 and back to 800 till the engine is warm (normal temp). then it idles great.
Could someone give me some pointers?
ricksgsrturbo
up and down idleing
Post by ricksgsrturbo »
u need to check your coolant, and check the hoses goin to your idle air control (IAC) valve and if coolant is at optimal level and you've bleed your coolant from air, you might have to replace the valve control, and for reference be sure to check vaccum lines for leaks
oscar93turbo
where is the iac?
Thanks for fast response
Djbower1
Post by Djbower1 »
its on the back of the intake manifold with 2 pipes coming from it.
TurboGSR96
Post by TurboGSR96 »
My car started to do this as soon as I installed the S300 and it did not do it with the factory ECU, I have not been able to get it to quit doing it.
585whp/385tq @ 21-23psi E85 Ethanol
OEM GSR Cams & Ignition
Also you should try adjusting the idle control duty cycle slider bar in Smanager.
TurboLS
Post by TurboLS »
yeah, i had the same issues. I think it has something to do with a setting that Hondata neglects when replacing one of the chips. Also, it could be your FITV (Fast Idle Thermo Valve). There is a good article on how to clean them on my team's site http://www.team-integra.net
TurboLS from Team-Integra.net
(703)919-2786 (C)
TurboGSR96
Spunkster wrote:Also you should try adjusting the idle control duty cycle slider bar in Smanager.
I messed with that in every little change +/- that could be made and it helped a little bit, but didnt fix it. My car starts to do it about 30 seconds after its started dead cold and stops as soon as the coolant needle reaches the first line on the gague.
See the tech article on setting idle speed and/or follow the idle setting procedure in the manual. There is too much bypass air past the idle valve - probably the throttle plate adjustment or idle bleed. Reduce the bypass air and/or raise the overrun cutoff.
