VSS & transmission problem/issue
unforgiven
Post by unforgiven »
I have an 05 RSX-S with an 04 ITR transmission which k-pro should I order. Is there any way to modify the harness to keep the vss the same and still have everything work. or can I just use the 02-04 model with no problem?
You will have to swap cases so that the speed sensor for the 05 can be fitted. But honestly there is no reason to swap transmissions. The gearing is the same, so you should just swap the LSD from the ITR transmission to the 05 transmission.
unforgiven
my previous case is shattered and pending warranty review...hence the new tranny. i may end up modifying the case for the vss. i'm sure a solution will come to me eventually.
