Open loop PRA ECU
Maverik
Open loop PRA ECU
Post by Maverik »
I?ve update K-Manager to V. 1.2.1.7 , but when I disable closed loop, my PRA ECU doesn?t go to open loop.
?the only chance I've in order to force my ECU to go to open loop is to set the 'Maximum MAP for closed loop' at a very low value.
This will be looked at in the middle of July when the person who does the K-Manager software returns from vacation.
Maverik
Post by Maverik »
My K-Manager version is 1.2.1.9 but my PRA ECU still doesn?t go to open loop by disabling the closed loop option on "parameters-closed loop".
Progger
Post by Progger »
Is this issue solved for the moment?
Maverik
Post by Maverik »
As far as I know this issue has not been solved yet. Anyway when I need to go to open loop I use to set Maximum MAP for closed loop = 10 kPa
Progger
Post by Progger »
And does the open loop work now?
Maverik
Post by Maverik »
Hondata says it has been fixed since V1.2.1.7.
I did some tests a couple of months ago with KManager V1.2.2.4 and it didn't work.
racing-honda
Post by racing-honda »
Did some street tuning yesterday.
Open loop still doesn't work on PRA ECU, using KManager 1.2.2.8....
Hondata?
