Disable error codes + calibration
Paulo
Post by Paulo »
I am installing a S300 in a Civic VTi 94 ECU P30 I have the following problem:
" The engine will only rev to 3200 rpm "
The error is in sensor MAP and injectors.
According to Hondata UK ecus it is necessary to disable the error codes
I didn't find in the manual as doing this.
Does anybody can me to help?
This is first S300 that I set up.
At once I thank
Paulo
You were not receiving a map error...it was atmospheric pressure sensor ...aka Barometric pressure sensor. These errors are normal on a UK ecu and must be disabled in the software, as the circuitry does not exist.
Paulo
Post by Paulo »
Ok Thank you for the answer.
I found the problem.
I enabled reltime update and I thought that with this the modifications of the parameters would be in real time. Then, I made the up load and it solved the problem!
I don't have experience with honda. How should I modify the vtec and the other parameters to win more power?
Does anybody have a calibration modified ready for me to use?
At once I thank
Paulo
Paulo
Post by Paulo »
Hello, am needing help.
I am already working in this civic the whole week and I don't get to have a potency earnings.
It is the first time that I work with S300 and cars honda.
Does anybody have a calibration for me to see how I should modify mine?
At once I thank
Paulo
I would highly recommend reading the tuning guide at http://www.hondata.com/stech.html
Paulo
Post by Paulo »
Thank you
I had already read the tuning guide.
It is that is first S300 that I install and I am with difficulties.
My English is very weak.
Would like to see a ready calibration to visualize how it was done.
Leaning that would be like this easier to understand.
Even so I thank the help.
[]s
Paulo
