Stage 3 help plz..
whitEjee
Stage 3 help plz..
Post by whitEjee »
I have an old stage 3 hondata from my old crx a couples yrs back. I now have a hatch decided to put it on just for the 2 step and full throttle shifter functions. I had a friend put the J12 4 pin thing into my ecu and its already chipped. now I ran all the wires and clutch etc.. started up my car reved it up to 6k just to see if its still set at 5500 like i had before i took it out. it reved pass to 6k so i stopped. now i then push the button to set functions but the check engine light doesnt' come on or blink. I looked at the blue box. the red l.e.d is blinking slow. Isnt' it suppose to be constantly on ? Can anyone tell me what's missing. Or any clue of what needs to be done for it to work properly?
Thanks in advance..
You have to put a Hondata ROM on the eeprom you are using and it will then need to be properly tuned to run gthe engine. You cannot just hook up the interface box and have the car run perfectly and use the 3-step functions.
whitEjee
Post by whitEjee »
gotcha thanx ima take it to LOCASH in Az. thanx!
