Iacv - s300
eaglekper0046
Iacv - s300
Post by eaglekper0046 »
Does the s300 have the ability to turn off the Iacv. Mine is bad and I dont want to spend the cash to get a new one.
It can turn off the error, but your ca may have idle problems without a IACV working. You should be able to find one in the junkyard or on www.car-part.com
TurboLS
Post by TurboLS »
what engine are you running? if it is a B series, there is a simple cleaning method you can do to make sure your valve is in fact bad, and not just a little dirty. Reply here if you would like to know how to do that.
TurboLS from Team-Integra.net
(703)919-2786 (C)
sulsa76
Post by sulsa76 »
Would this cleaning method consist of more than spraying carb cleaner into it? I bet mine could use a cleaning.
94 Integra LS with NA GSR block/head
Endyne pistions, 14 pound flywheel, Civic SI crank pulley, honed gsr intake manifold, 70mm BBK TB, Stock GSR cams, stock exhaust/header
pvt_awol
Post by pvt_awol »
I'm running an S300 on a boosted LS/VTEC OBD1 civic. The intake manifold is OBD0 b16. I removed and blocked off the IACV all together, and didn't make any changes in the S300 calibration.
With that said:
When I start the car COLD, it idles low (like it would without the valve) and I just have to make sure to warm it up before I drive it. When the car is WARM, there is no problem and the car works fine. So, if you're IACV is bad, it shouldn't make that much difference than to just unplug it.
sulsa76
Post by sulsa76 »
That's good info! Thanks for posting it.
