At wide open throttle, hondalogger reads 88%.
ITEracer
Post by ITEracer »
Should every properly working TPS read 100% in logger? The throttle plate is open all the way at WOT, but logger reads 88% maximum. In my old logs, the highest I would see it go is 92%
Small power loss lately, trying to figure out why.
Still trying to make somethin outta nothin
turbosi92
Re: At wide open throttle, hondalogger reads 88%.
Post by turbosi92 »
ITEracer wrote:Should every properly working TPS read 100% in logger? The throttle plate is open all the way at WOT, but logger reads 88% maximum. In my old logs, the highest I would see it go is 92%
Your TPS sensor isn't set properly.
What does it read at idle?
ITEracer
now it reads 5%
Post by ITEracer »
At first, I had it set to where it would read zero or one percent. I raised it up a few percent to see if it would make a difference in the reading at WOT. It didn't. It seemed to go lower when I raised the idle. Does this make sense?
No. Can you tell me what voltage it is now reading at idle?
