closed loop
Wolli
closed loop
Post by Wolli »
Hello.
I?m using the s300 in my civic with p30 ecu. i also have a innovate lc1 wideband lambda, a crower stroker kit 1,9l, 9:1 je pistons, rc 750 inj., walbro fuel pump, supercharged to 16 psi, crane cams ignition, ferrea valves etc., and much more. the engine is running good in open loop, but when i go to closed loop, he gets much to rich. i set the target voltage to 2.5 volts, that?s the voltage my lc1 is at labda 1. but the s300 goes to somewhere under 1 volt. i do not find out why. i have the newest version. also when i try to create a forced induction table, it resets it always. i?m not able to change it.
You CANNOT run in closed loop using a wideband signal. You must set it up per the instructions at http://www.hondata.com/techplxwiring.html
Wolli
Post by Wolli »
But only US models does have the ELD, correct?
I believe all ecus have the internal circuitry for the ELD input, but it can only be used with the Hondata.
scoobs187
Post by scoobs187 »
Do you have to change anything in the Parameters after doing that ( http://www.hondata.com/techplxwiring.html )?
You may have to change the closed loop settings depending on how you have it wired.
