timing question
B16T
timing question
Post by B16T »
hello im running a stock b16 2nd gen engine with a turbinetics TO4E with a .58 hotside, my question is its alittle sluggish from like 2200-3500 and theres only about 20 degreese of timing in that slota and no boost yet , im running 20 degreese at 4psi, 9psi and running 17 degreese at WOT from Vtec point witch is set at 5800 to 8200, and i get about 4psi at 5k any help on Timing in VAC is helpful, also im running a LS tranny if thats helps at all, So basicly whats a good # to run in VAC before the turbo spools thanks JOSH
Load a stock calibration into Smanager and take a look at the timing tables. You really need to tune this on a dyno.
