Help PLZ - 96 SRV with 93 H22 JDM Vtec - Which ECU?
JarekN
Post by JarekN »
I hope someone can help me out here...
I have an 96 SRV with manual transmission... The car had a 93 or 94 JDM motor put into it a while ago ... It seems like my ECU is dead now and I want ot make sure I get the right one... That being said based on what I've read so far it says that 96+ preludes require OBD II ECU... is that requirement based on the year of the car or on the motor? That is since my car is 96 do I get an ODB II ECU or since the motor in it is a 93 JDM do I get an ODB I?
Also since the engine is JDM do I need a JDM version of the ECU?
And last what would the part number be for each of those?
PLZ HELP :cry:
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100, s200 or s300 depending on what options you want.
JarekN
Post by JarekN »
96 has an obd II ECU... I was looking for the part number of the stock ECU for it...
