Alpha-N problem. Hiccups
CivicVTi
Post by CivicVTi »
I have major hiccups under very low throttle openings. The TPS has been set to 0% when throttle fully closed. Under light throttle (<8%) the car sometimes goes to injector cut off mode as shown in the datalogging with no reason (since TPS>0%). Any ideas?
Setup: B18c with ITR cams and custom ITBs.
You might try changing the over run cutoff in the Rev Limits tab of Parameters.
CivicVTi
Post by CivicVTi »
Also tried it. It didn't work..
What did you change it to?
CivicVTi
Post by CivicVTi »
I tried both a very low value (1000rpm) and a very high (4000rpm). Almost nothing changed
please pos tthe calibration and also datalogs showing the problem
