New to Hondata, quick question
Red98GST
Post by Red98GST »
Ok, I recently ordered an S200 system for my ek hatch since I almost have everything needed for the turbo kit. The question I have is, what ECU do I need to look into grabbing. A lot of people have said a P28, but the thing is, I have a B18B right now and plan on swapping a B16 head on in the next few months. Would the P28 be fine even with the B18B set up?
Also, what else is needed for the set up? Right now, I have the S200 system, injectors, pump, and plan on grabbing an ecu within the next week or so. Someone said I do not need a 3 bar map sensor since I dont plan on running more than 11lbs right now.
Thanks,
Chris a.k.a Hondata noob
The P28 will be good for either setup. You may want to reconsider the s200 and sell it and get the s300. For $100 more you get the ability to tune everything on the fly via usb without the need for burning chips all the time.
Red98GST
Post by Red98GST »
So pretty much since I have the Hondata system(got it in the mail today), obd2 to obd1 adapter harness, is there anything else I need besides the actual ECU it self?
