2nd intake manifold gasket for K24
outersquare
Post by outersquare »
just as a product idea for hondata, the K24s might benefit from another heatshield gasket inbetween the two pieces of the intake manifold.
Since apparently the injector base still runs coolant through it, it warms up the manifold after the gasket.
The first piece of the intake manifold/plenum has no such coolant ports.
No additional gaskets will be made, as there is no need for them, once you have eliminated the head as a source of heat then you will get no further gains by using an additional gasket on the other part of hte manifold.
outersquare
Spunkster wrote:No additional gaskets will be made, as there is no need for them, once you have eliminated the head as a source of heat then you will get no further gains by using an additional gasket on the other part of hte manifold.
does the coolant running through the injector base still not heat up the manifold?
