stupid question
rotten777
stupid question
Post by rotten777 »
i recently upgraded to the latest version of the k-manager and retuned my ep3. i reset all the same parameters (idle, rev limit, 2 stage, etc.) and now i have a green key flashing on the instrument panel.
immobilizer is disable. i'm confused. any help?
ep3
If you disable the immobilizer the immobilizer light on the dash will flash unless you unplug the unit around the key.
rotten777
Post by rotten777 »
Hondata wrote:If you disable the immobilizer the immobilizer light on the dash will flash unless you unplug the unit around the key.
unplug the unit around the key?
which unit are we talking about?
why did this happen only when i upgraded the software?
ep3
jerseyjew
Post by jerseyjew »
Have you tried enabling it? What Hondata is saying is that if it's disabled the immobilizer also needs to be unplugged.
rotten777
Post by rotten777 »
jerseyjew wrote:Have you tried enabling it? What Hondata is saying is that if it's disabled the immobilizer also needs to be unplugged.
enabling it makes the car not start. where is the immobilizer so i can unplug it? i never plugged anything in to cause this. that's why i'm so confused.
ep3
Have you tried clearing security and uploading the calibration agian? You may also try clearing security and uploading a new PNF calibration to see if the problem goes away...perhaps your calibration is corrupted.
rotten777
Post by rotten777 »
Spunkster wrote:Have you tried clearing security and uploading the calibration agian? You may also try clearing security and uploading a new PNF calibration to see if the problem goes away...perhaps your calibration is corrupted.
How do I clear the security? I will try that.
ep3
from the top: Online, Tools, Clear security
