logging AFR
94vtirozguy
logging AFR
Post by 94vtirozguy »
i have a bug with software where when datalogging with s300 unit and you update the ECU , datalogger logs the wrong AFR (10.00) when the PLX-M300 is still logging the correct AF ratio.
the only way around this i can find is turn off car and it all working again.
Any ideas on this bug and when it will be fixed ?
Read this before posting
Which input have you connected the M300 to? Can you provide a datalog?
94vtirozguy
details
When reporting any s300 problems, please include:
- the calibration
done as per document http://www.hondata.com/techplxwiring.html
- a datalog of a problem
will attach in the next few days.
- what sort of vehicle you have
99 prelude
- what sort of ECU you are using
P28
- anything about the car which has been modified from stock which may
stock except custom exhaust
- a specific description of the problem
when datalogging AFR randomly reported by hondata = 10.0 even though the PLX says otherwise.
Then after certain time will start loggin normally again ( AFR in hondata matches the PLX M300.
