Reflash #4 + IceBox
kenrsx04
Reflash #4 + IceBox
Post by kenrsx04 »
Is Reflash #4 + IceBox work OK? Is it going to run too lean or too rich?
We recommend a true cold air intake, as people have had problems with detonation with the icebox.
madru17
Post by madru17 »
what causes the the detonation?
drumnatural
Post by drumnatural »
Spunkster wrote:We recommend a rue cold air intake, as people have had problems with detonation with the icebox.
What people? How did they know for sure it was detonation?
Was this during idle, crusing, and/or WOT?
madru17
Post by madru17 »
So do you guys ever answer your customers questions?
Using the Comptech Ice box caused detonation....since we did not test with this modification I cannot say what exaclty caused it, but probably restriction or excess heat.
And people indicates those that reported detonation while using the icebox and the reflash.
I would suggest searching for this information on Clubrsx as that is where it was discussed.
http://forums.clubrsx.com/showthread.ph ... ox+reflash
http://forums.clubrsx.com/showthread.ph ... ash+icebox
Plasma69
Post by Plasma69 »
hey you 2 are tools :roll: , relax, why don't you do some research b4 gettin excited over nothing. these guys are nothing but super helpful.
johcor
Post by johcor »
I know this is an old thread. I just want to point out that Hondata alluded to the Icebox when they dyno'd their reflash with the '06 TSX.
The link is:
http://www.hondata.net/reflash_tsx_06.html
The comment they made about the dyno chart reads:
Note the loss in torque from 2400 to 3200 rpm. Intakes such as the Comptech Icebox will not do this.
While this isn't a recommendation for the Icebox, it doesn't underscore the larger issue of detonation. The TSX and the RSX-S use the same engine, although the underhood layout is probably different. Still, the Icebox comment on the TSX raises a lot of questions, particularly in the context of possible detonation for the RSX.
