does 93 gas make more power than 89 gas in the base reflash?
jad1217
Post by jad1217 »
does 93 gas make more power than 89 gas in the base reflash? i saw the dyno used 89 but it said that 91 was recomened, i have 93 gas here in florida. will i be makeing more hp and tq than in the dyno graph if i use 93? also if i wanted to run 89 gas with the reflash will this damage my engine? :D
jad1217
Post by jad1217 »
bump
You will not make more power with 93. You should not use lower than 91.
