95 accord f22b1 vtec (s300?)
MaXiMuS
Post by MaXiMuS »
Hi all, im new to these forums and had a question.
i have a 95 accord that i just put an f22b1 Vtec engine in which is running on the P0A ECU. I was wondering if the s300 will work with this ECU or would i have to obtain another ECU to run this car with an s300.
Thanks for your help
MaXiMuS
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html
