s300j boost options
dumas07
s300j boost options
Post by dumas07 »
Hey i am about to buy a s300j for my 1999 integra LS. I am in the making of putting a custom turbo kit on my car piecing it together and i was wondering is there a way to plug in and have boost control through the s300j, or do i have to buy a seperate boost controller....i dont know if i buy a seperate one will it still adjust the hondata according to the boost level i set?????
also i only need to buy the s300j, clutch switch, and a obd2 to obd1 conversion harness for a complete install correct?????
also is there a way to set the launch control to only activate with a hotkey or something.....because i dont want my car to activate the launch control rpm limiter everytime i push in the clutch!!!!
thanks for any help
justin
YOu cannot control the amount of boost withteh s300j, but you can tune under boost conditions for fuel and timing. You should download the Smanager software and take a look at how it all works.
http://www.hondata.com/smanager.html
