12psi on stock map sensor? is it possible
B16T
Post by B16T »
hey guys tonight i installed a 12psi wastegate spring, but soon as it builds like 10-11 psi it cuts out, and i thought you can run 12 on the stock sensor, the map goes to 12 on the S300, also i read something about tricking the stock sensor so you can run 12psi, if anyone has any good or bad info im all ears thanks, also got my full throttle shifting working Mint, and the Af ratio reading though the display screen thanks JOSH
GTMcoupe
Post by GTMcoupe »
Stock honda sensor max is 10 Psi
West
If you wish to boost higher than 10 psi you need to get a 3bar map sensor. You should never trick the ecu as it defeats the purpose of having a fully tunable system.
B16T
Post by B16T »
Thanks guys yea i though it was 10 i was reading someones post on hondatech and they said they changed the voltage on the stock map to read 12psi ut i didnt think it was possible or a good idea, thanks though
BlueTurboteg
Post by BlueTurboteg »
Hey howd you get the AF reading thru the display??? my car wont show anything on the display..im actually having problems getting my 3 bar working too(waiting on some replys)my car also cuts out over 10 psi. but runs great
Please try looking in the tech section of our website...the answers to most questions and problems can be found there.
http://www.hondata.com/techplxwiring.html
http://www.hondata.com/tech3barmap.html
