Whole ECU's
The Scattareggia
Whole ECU's
Post by The Scattareggia »
So Hondata doesn't offer whole ECU's? Just the chips to put in and mod the stock one? And if I were to buy an ECU from a different company would the Hondata s300 still work in it? Although I guess there really wouldn't be a reason to. Thanks for any help.
The Scattareggia
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s300. You can buy Socketed P28s through any Hondata dealer with or without an adapter harness built in for OBD2 vehicles.
