Something fried!!!
ragethemachine86
Something fried!!!
Post by ragethemachine86 »
To keep things short, i messed up on the injector wiring for dsm injectors on a 97 prelude. Had one of the cables switched.
Now car doesnt start.
-No fuel pump prime when i turn car on ON.
-Replaced main relay.
-Tried stock ecu and same results.
-I noticed though that when i hook up my p28 with s200b the little red LED on the hondata unit does not come on, even with a brand new interface cable.
-Checked all fuses
Anyone know what the hell is going on??? Why wont the fuel pump come on???
You may have blown a fuse...check your fuses and wiring. If you are unsure of what you are doing, it is recommended that you take it to a professional.
boostnlsr
Post by boostnlsr »
double and triple check your fuses. had the problem with my ls/vtec turbo. took the speed sensor wire to clean it and accidently arced it. went to start the car and no fuel pump prime. i could not figure out what it was too. i checked fuses...even had my cousin check it too...long story short it ended up being a fuse that looks like it is in a "spare slot."
