coils
h2nrtl
coils
Post by h2nrtl »
anyone have a wiring diagram for setting up aftermarket coils like msd ss blaster to work with Kpro?
You will be much better off using the stock coilpacks as aftermarket ones will cause more problems for you and will probably disrupt datalogging.
h2nrtl
Post by h2nrtl »
will I have a high CR allmotor K24 and it seems like the spark is giving up above 8500rpm. I know other teams like the clutch masters team are using them on there engines.
The stock coilpacks have been able to run 600 hp turbo applications without any problems.
Razathorn
Post by Razathorn »
h2nrtl wrote:will I have a high CR allmotor K24 and it seems like the spark is giving up above 8500rpm. I know other teams like the clutch masters team are using them on there engines.
What is the CR?
The honda coils are quite overpowered if I remember correctly from one of Doug's responses.
Wayne
